Gold spots and master cylinder
Kolyzer
Hi guys
I bought a TRX this spring and I am loving it so far. I do feel that the front brake is lacking bite. So I have decided to upgrade to the gold or blue spots. I have sourced the parts on eBay I just need confirmation that it is the correct parts.
Master cylinder:
https://rover.ebay.com/rover/0/0/0?mpre ... 3780784316
Gold spots:
https://rover.ebay.com/rover/0/0/0?mpre ... 3822826325
Thanks in advance
Mike
Master cylinder:
Gold spots:
Thanks in advance
Mike
Re: Gold spots and master cylinder
Master cylinder will have a 14 stamped on the underside where the std trx will have 5/8.
Gold spots will fit ok.
Braided lines make all the difference too than the old rubber std lines.
Kolyzer
Cool i Will contact the seller and ask about if it is stamped with 14.
Regarding the braided lines, would you recommend any brand in particular?
- jpe70
It most certainly is since early R1 and R6 use the same brakes. Otherwise just get a master for a 98-02 R1, it's really the same item but guaranteed a fit.Kolyzer wrote:Cool i Will contact the seller and ask about if it is stamped with 14.
Not really any recommendations, I use Wezmoto because they look good and comes for a reasonable price: http://vi.raptor.ebaydesc.com/ws/eBayIS ... 5895065974
Kolyzer
Thanks man. I see you have linked lines for a r1, will the length be okay for a TRX?jpe70 wrote:It most certainly is since early R1 and R6 use the same brakes. Otherwise just get a master for a 98-02 R1, it's really the same item but guaranteed a fit.Kolyzer wrote:Cool i Will contact the seller and ask about if it is stamped with 14.
TRX will need longer lines than an R1 / R6 but the TRX lines will fit into the spot Calipers ok.
Kolyzer
Thanks cobbacobbadiggabuddyblooo wrote:TRX will need longer lines than an R1 / R6 but the TRX lines will fit into the spot Calipers ok.
There is quite a number of bike that use a 14mm M/C.
Talk to a motorcycle wrecker and ask for a 14 mm master as you may find what you need a lot cheaper...
- jpe70
Yes, I use the R1 lines. I have slightly lower bars than stock, but lines are long... I think (can't really remember) it was the stock R1 lines mounted before with stock bars.Kolyzer wrote:Thanks man. I see you have linked lines for a r1, will the length be okay for a TRX?jpe70 wrote:It most certainly is since early R1 and R6 use the same brakes. Otherwise just get a master for a 98-02 R1, it's really the same item but guaranteed a fit.Kolyzer wrote:Cool i Will contact the seller and ask about if it is stamped with 14.
keny72
So folks suggest a 14 mm M/C whit the blue spots? Not the stock 5/8 that is ~16mm? Some Yamaha´s use a 16mm M/C whit the blue spots, like the YZF1000/750, the FZS600/1000 use a 14mm M/C however
- jpe70
The size differs depending on whether it's a radial or "normal" master. Old style 14 mm pump equals 16-17 mm radial pump. And yes, the suggestion would be the M/C that comes with the calipers, not the TRX stock or similar. It will work, but you could just as well saved your money and changed the lines only.keny72 wrote:So folks suggest a 14 mm M/C whit the blue spots? Not the stock 5/8 that is ~16mm? Some Yamaha´s use a 16mm M/C whit the blue spots, like the YZF1000/750, the FZS600/1000 use a 14mm M/C however
