Std TRX rear shock rebuild deal. 1st March 2019
jpe70
Re: Std TRX rear shock rebuild deal. 1st March 2019
Post by jpe70 » Tue Feb 11, 2020 12:21 pm
A while ago, but let's hop on with a followup. My shock is grounded at the workshop, are there by any change specs from this deal available? Like gas pressure and oil weight?
I seems they can't revalve the shock, but should be able to put it back together with some info (that they can't find themselves).
jpe70
Post by jpe70 » Thu Feb 13, 2020 5:29 pm
jpe70 wrote:A while ago, but let's hop on with a followup. My shock is grounded at the workshop, are there by any change specs from this deal available? Like gas pressure and oil weight?
Got some answer from a nice chap named Paul at MPE. Suspension oil 3wt is the going fluid for TRX shocks, and a needle for self sealing units to insert the nitrogen. Racetech or other. Also, the (discontinued) YA524 Öhlins shock is the one to read up on for reference.
Just thought I note it down if you feel like doing this yourself some day.
Post by cobbadiggabuddyblooo » Fri Feb 14, 2020 12:03 pm
Wow that was a fast reply... =D> =D>
Glad Paul could help you out.
He’s looked after quite a few of us lads here in Oz with their TRX’s ...
Rod.s
Post by Rod.s » Fri Feb 14, 2020 1:24 pm
cobbadiggabuddyblooo wrote:Wow that was a fast reply... =D> =D>
He'll be doing my other TRX's rear shock and the Husqvarna's suspension!!
Rod.s
Post by Rod.s » Fri Feb 14, 2020 1:26 pm
https://www.ohlins.com/app/uploads/worl ... _YA524.pdf
Bricktop
Post by Bricktop » Sat Dec 03, 2022 12:43 pm
How did all this pan out? I’ve finally put silver spots on with and 14mm M/C, and now turning my attention to forks and shock. Mild improvement up front with spacers and oil change, until I can afford something more substantial. But if I can sort the rear out for under $300 I’d be stoked, understanding I’m years late here.
Post by davamb » Sat Dec 03, 2022 6:40 pm
Hey Bricktop,
I've got my shock from that rebuild deal that I've never used. Am open to a decent offer if you're interested. I'm down near PI in Vic.
Post by davamb » Wed Dec 14, 2022 6:23 pm
I've PM'd Bricktop, but he hasn't been back or read the PM. Does anyone else here know the chappy and can get him a message? Craybait is also keen on the shock and I'd be happy to see it go to him if Bricktop can't be contacted in a reasonable timeframe.
