Thought I’d put a database together of brake pads common for the TRX showing
Genuine part number
Pad size
Aftermarket part number
Good link here on something I put up a few yrs ago about pad manufacturing and codings.
http://www.trx850.com/phpBB_forum/viewt ... ad#p107513
https://www.metalgear.com.au/view_model ... l_id=10414
Std TRX SUMITOMO Calipers
Genuine part No..
Pad Size ... 74.8mm x 54mm x 9.4mm
DP part No. DP 410 or SDP 410 ( sintered )
Metal gear. 30-105 (organic) 30-105-S (sintered)
Std TRX Rear Caliper
Genuine part no..
Pad Size 63.8mm x 55mm x 8.7mm
DP part no DP 404 or SDP 404 ( sintered )
Metalgear 30-012 (.org)... 30-012-K ( Kevlar ) S ( sintered )
Std Japanese import TRX BREMBO Calipers
Genuine Brembo part no. 07BB 19.90
Pads size...... 71.1mm x 55.5mm x 8.7mm
DP Sintered pads part no. SDP 630 HH+
Metalgear. 30-101 ( organic ) 30-101-S (sintered)
SUMITOMO Blue/Silver/Gold SPOT Axial Calipers ( 4 piston )
Genuine part no..
Pad Size... 69.8mm x 51mm x 8.8mm
DP sintered part no.. SDP 418
Metal gear. 30-006 (organic) 30-006-S (sintered)
SUMITOMO Silver/Gold Radial Calipers ( 4 piston )
Genuine part no...
Pad size 69.8mm x 51mm x 8.8mm
DP Sintered part no. SDP 418
Metal gear 30-006 (organic) 30-006-S (sintered)
Later model 6 Piston spot caliper
Genuine part no...
Pad sizes 61.9mm x 44.7mm x 8.5mm + 30.9mm x 48.1mm x 8.5mm
DP sintered part no. SDP 976
Metal gear 30-293-S
BRAKE PAD DATABASE
BRAKE PAD DATABASE
- Rod.s
Re: BRAKE PAD DATABASE
1995 front caliper,
Gold Brembo,
Genuine Brembo #07BB19.xx this number can be cross-referenced to many others
Metal gear. 30-101 (organic) 30-101-S (sintered)
Calliper bolt sizes...
-M10P1.25 Length 30mm Black Chromate
Part No. 90105-10725
-M10P1.25 Length 30mm Electroless Nickel Plated
Part Number 90105-105A7
-M10P1.25 Length 37mm Electroless Nickel Plated
Part No. 90105-105A0
All have a diagonal of 12 mm and a flange diameter of 19 mm.
Gold Brembo,
- Rod.s
correctcobbadiggabuddyblooo wrote:What’s the piston sizes 30/34????
Yamaha Part numbers for the seals..4HM-W0047-60 and 4HM-W0047-50 one set is 4 seals enough for two pistons..
