Polarity change on TPS when running TDMR 40
Posted: Sun Nov 11, 2018 1:46 pm
https://m.youtube.com/watch?v=QA8g89oXyZY
How to change the polarity on the pins with your TPS .
A must if running TDMR carbies due to the TPS mounted on the opposite side.
Re: Polarity change on TPS when running TDMR 40
Posted: Mon Nov 12, 2018 12:18 am
by PrfctChaos
Im not sure the TPS does too much. I run a set of TDMR carbies and one of the ignitech ignitions. No TPS and runs just fine.
From memory I think with a TPS enable there is only a change in the timing sub 20 or 30% throttle opening. But I think my bike behaves well at small throttle opening, with TPS disabled.
Posted: Mon Dec 02, 2019 8:30 am
Here you go David in case the link doesn’t work...
