trx 850 to 900 conversion problem(?)
Posted: Mon Sep 11, 2017 3:51 pm
by arisitia
hello from greece!!
i am a trx 850 owner and i am planning to put a tdm 900 engine in the frame.my problem is that i dont want to use the EFI,so the head and the carbs will be from the trx.the question is what to do with the electric harness.does thes trx's stator fit the tdm's rotor?or what else can i do?
thanks in prompt and keep up the good mods!!
Re: trx 850 to 900 conversion problem(?)
Posted: Mon Sep 11, 2017 5:48 pm
arisitia wrote:hello from greece!!
I´ve done exactly that, i have trx ign, oilpan (with adapter plate made in germany) head and flatsslides....
I think i did a thread in here somewhere on what had to be done.
You also need custom sprocket at front and exact spacers for sprock in the rear...
EDIT:
You can get almost all you need from this guy:
http://www.moto-twins.de/index.php?cat= ... auten.html
