1200?
1200?
Post by coxylaad » Tue Mar 07, 2017 11:05 am
has anyone bothered to check to see if there is any interchangability between the new super tenere 1200 and the 850/900 ?
The castings themselves look completely different, but the heads might fit on? maybe?
That would be really nice. it would give the engine big hop in mid range torque.
oh and just as a side note it has a lug on the back of the cylinder head where it was deleted on the 900.
Re: 1200?
Post by coxylaad » Tue Mar 07, 2017 11:32 am
Re: 1200?
Post by Mincehead » Tue Mar 07, 2017 7:51 pm
Nope, it won`t work. If it did the race boys would`ve already done it. :wink:
Re: 1200?
Post by davamb » Tue Mar 07, 2017 11:12 pm
Don't discourage the poor boy Mince, I'm keen to see him have a bash at it!
Trixed
Re: 1200?
Post by Trixed » Wed Mar 08, 2017 6:06 am
I would use the Super tenere frame and rear swing arm as that is setup with shaft drive paraphernalia.
Change front end to modern day r6. fairing or naked as preferred. Easiest route if the frame from the tenere is not damaged.
I actually have already thought of the possibilities when the tenere was first released :)
Good luck!
Re: 1200?
Post by coxylaad » Wed Mar 08, 2017 10:02 am
Mincehead wrote:Nope, it won`t work. If it did the race boys would`ve already done it. :wink:
:D Said with utter confidence. like when they said you couldnt shoe horn the full 900 complete with oil tank in the TRX frame... which has now been in my bike for 4 years.
Re: 1200?
Post by coxylaad » Wed Mar 08, 2017 10:19 am
Trixed wrote:I would use the Super tenere frame and rear swing arm as that is setup with shaft drive paraphernalia.
Good luck!
Yeah I thought about that but then it wouldnt be a TRX anymore, i may as well just buy and run a superten. If i got an engine I would ditch the output shaft, i am sure that there is a take off for the front
Engines are still pretty expensive at the moment. but maybe one day. They don't actually produce that much more power than the 900 or 850, but they must have a lot of torque.
Re: 1200?
Post by dandywarhol » Wed Mar 08, 2017 11:41 am
Don't be discouraged laaaad - it it could fit then Coxy would make it fit! 8)
I was singularly unimpressed with the 1200 Tenere - ok, its a heavy mother but the fuelling/mapping and fly by wire/electronics made it dull to ride. But in theory, a 1200 twin SHOULD be made to go well.
Quite different bore/stroke - TDM900 92 x 67.5mm - 1200, 98 x 79.5mm http://www.motorcyclespecs.co.za/model/ ... 0%2009.htm
Overlord Neil
Re: 1200?
Post by Overlord Neil » Wed Mar 08, 2017 8:30 pm
I've been thinking about this engine in the TRX aswell, not that I'll be able to o anything about it for about 18 ish years... But, in theory the TRX frame should be the easiest thing in the world to fit another engine too, its steel so you can chop and weld to your hearts content and the bottom half of the frame is an aluminium cradle that could be a machined block to suit what ever was going to show horned in place. You'd probably struggle with an inline 3+ cylinder, not sure how wide the super ten engine is but theres nothing in the rule book to say you couldn't make the frame a little wider to suit...
I say go for it ;)
Re: 1200?
Post by Mincehead » Wed Mar 08, 2017 9:39 pm
A TL1000 motor will fit `within` the TRX frame. :twisted:
Re: 1200?
Post by coxylaad » Thu Mar 09, 2017 10:16 am
dandywarhol wrote:Don't be discouraged laaaad - it it could fit then Coxy would make it fit! 8)
a squarer motor yes? in theory that should rev harder?
all just thoughts, I would probably build a new TRX from scratch rather than pull my 900 to bits. its never let me down and has impeccable manners.
just need to find a totalled super ten for a grand and I will make it happen :lol:
Re: 1200?
Post by coxylaad » Thu Mar 09, 2017 10:17 am
Mincehead wrote:A TL1000 motor will fit `within` the TRX frame. :twisted:
If I could choose an engine to go in I would have a look at a vfr800 pre V tech lump.
you can get those quite cheap, and you can make them sound like motogp bikes, just need to see if it would fit in the frame
Re: 1200?
Post by dandywarhol » Thu Mar 09, 2017 11:30 am
Long stroke, which the 1200 has, should give good torque. The more over square the motor the revvier, producing more power. Have a look at F1 engine bore and stroke and why they rev so high.
Shorter stroke means lower piston speed (less travel) therefore will allow higher revs. Basically power is torque times revs, the higher the revs, the torque is done in a faster time and produces more power .
Lesson over :lol:
Re: 1200?
Post by coxylaad » Thu Mar 09, 2017 6:31 pm
Sorry I got the bore and stroke measurements back to front. It's all about maximum piston velocity I believe.(edit sorry you already said this - never read it properly on my phone!) Longer stroke make bigger piston speeds for the same revs.
Maybe I should look into the trx/vfr800 hybrid. 120bhp would be a lovely power figure for the road. I wonder how heavy the very engine and swingarm is.
Overlord Neil
Re: 1200?
Post by Overlord Neil » Thu Mar 09, 2017 9:04 pm
Funny its switched to a honda V4, I was actually thinking about an ST1100 lump and drive train, maybe not motogp spec but plenty of torque and i'm sure with half a tonne of fairing removed you'd get some grin inducing poke.
