Fitting an R6 Shock
Posted: Mon Oct 03, 2016 9:27 pm
by Tealman
I know there are different trains of thought as to whether the standard shock should be replaced or rebuilt, but I've gone ahead and bought an R6 shock anyway. I've also bought the Projection Components (PC) fitting to give the assembly the correct length and wondered whether the R6 lower shock to PC fitting uses the same bolt used to attach the standard shock bottom fitting to the frame? Cheers :D
Re: Fitting an R6 Shock
Posted: Mon Oct 03, 2016 9:39 pm
by highlander
R6 shock to PC extender = R6 bolt
PC extender to TRX dogbones = TRX bolt
Posted: Mon Oct 03, 2016 10:38 pm
by Tealman
Excellent - thanks for the heads-up. Now I can order the right part :D
