FZR400 Wheels on a TRX
- Overlord Neil
Does anyone know if the FZR400 wheels will fit a TRX? Theres a guy selling some Dymags on evilbay.
Re: FZR400 Wheels on a TRX
Main thing to check is the disc size or bolt pattern to match a 298-300mm disc if the trx one doesn't bolt straight on.
Off set can usually dealt with spacing the disc or caliper. Axle size can usually be worked I around too.
The rear Dymag disc carrier can be modded or replaced if needed if the disc doesn't suit and rear sprockets are readily available for early Dymags.( pre 2000 )
2000-2002 Dymags had issues with the rear sprocket carriers but the problem was sorted after a bad run for 2 years.
Check if the rear sprocket size is a 63 centre hole, 95mm bolt pattern centres as that is the early( pre 2000 wheels.
Sprocket carrier is the easiest way to gauge the age of the wheels
