pom in nz
by pom in nz » Sun Jan 03, 2016 11:27 am
ok guys, I have some nice 2007 YZF Thundercat forks for the old TRX.
just wondering what fork oil weight would suit...................im 70kg all up!
ps. I already have the R6 rear shock.
highlander
by highlander » Mon Jan 25, 2016 5:47 pm
Std is 10 SAE, you should sick with that unless you are changing the springs as well and tuning the front end.
