Hoses for blue spot up grade
fatal
Post by fatal » Sun Dec 13, 2015 10:57 pm
Hi guys, just bought a pair of blue spots, but the question is, what braided hoses do I need
Is it a case of buying a set of r1 or r6 ones or do I need a custom length to fit the TRX
highlander
Re: Hoses for blue spot up grade
Post by highlander » Tue Dec 15, 2015 12:45 pm
Std TRX should work, did for me .... but I assume you're asking because you measured up the new brakes and the hoses don't reach???
fatal
Post by fatal » Tue Dec 15, 2015 10:19 pm
I haven't had time to install them yet, but I had read the the angle of the banjo that bolts to calliper was the wrong angle
M.V.
Post by M.V. » Wed Dec 16, 2015 2:42 am
I used standard HEL lines, l but flipped them around at the caliper end.
fatal
Post by fatal » Wed Dec 16, 2015 7:42 pm
Thanks for the info guys, hopefully get them fitted over the Xmas break
