gday,anybody here drilled and tapped their forks for a drain screw?looking at a mates trx and figured it wouldn't be a bad idea for easier oil changes.
EDIT,posted twice somehow?i got error message first time,no worries.
fork drain plug
Re: fork drain plug
Yep, easy enough to do, tap a 5 mm thread in there and use a small end cutter to face it off flat so you could use a copper washer under the bolt head.
Re: fork drain plug
thanks mincehead,i can handle that,seeing the forks are coming off ill kill two birds.
