Ducati front end?
devonnick
Re: Ducati front end?
Post by devonnick » Thu Feb 18, 2016 9:20 pm
cobbadiggabuddyblooo which dt swingarm spindle did you use there are many DT's to choose 50..125...175 etc thank you .
Post by cobbadiggabuddyblooo » Thu Feb 18, 2016 11:12 pm
Don't know.. But a tape measure and a trip to a wreckers and you'll find a swing arm pivot pin for the job. Mine was done by a motorcycle engineering shop and he had a bucket full of them of various diameters and through the course of the conversation mentioned about the DT swing arm pin.
But the photo gives you the gist of what needs to be done.
As long as the pin is long enough and the correct diameter, you'll be right.
devonnick
Post by devonnick » Thu Feb 18, 2016 11:23 pm
Thanks ...does the larger spacer have to be welded to the spindle I was thinking of making aluminium spacers for each end drilled out to 17mm for a steel spindle to pass through I have large amounts of alloy bar which would be lighter as well . thanks again.
