ok peoples,
I have had a good search but came up blank, can I fit Thunder Ace forks to my Trx,
I know about the 600 version fitting. its just I have the chance of a full front end from the 1000
thunder ace forks
- pom in nz
thunder ace forks
Re: thunder ace forks
Just check they may be 43mm diameter and not 41mm.
You can always machine the triple tree to accommodate which would be an easy solution
it's only 1mm removed all the way around..
- pom in nz
ah, thanks for that. so all the rest of the trx parts can be used, ie: wheel, axle and speedo drive?
