FZR 400 Headlights
Posted: Sat Feb 17, 2007 11:02 pm
by Steelback
Am I right in thinking that you can fit the twin headlights from an fzr 400 onto a TRX? If so how easy are they to fit and what model should I try to get them from? :?
Re: FZR 400 Headlights
Posted: Sat Feb 17, 2007 11:13 pm
Steelback wrote:Am I right in thinking that you can fit the twin headlights from an fzr 400 onto a TRX? If so how easy are they to fit and what model should I try to get them from? :?
Bolt on fit, only a spur.
You should get the one that looks like the TRX´s....don´t know for sure but i think they´ve made ´em with dual glass also....
just as the FZR600 wich i got, they differ a bit...the 600 has a "standard" low beam and a projector high beam on the other side.
(look in member ride´s section on my pic of front)
Posted: Sat Feb 17, 2007 11:20 pm
by Steelback
:D Many thanks - will give it a go
Posted: Sat Feb 17, 2007 11:25 pm
Steelback wrote::D Many thanks - will give it a go
You might want to consider your UK MOT rules, in Sweden we can only have ONE light lit in low beam....
Posted: Sun Feb 18, 2007 6:05 pm
by Steelback
Should be ok
Posted: Wed Feb 21, 2007 1:40 am
by Greg
I picked one up that has two projector units ...
All I need now is an HID kit and I'm hot to trot!
G
Posted: Wed Feb 21, 2007 5:25 am
by Kevtrx849
Heres something to consider. I have the twin projector type headlight fitted (goes straight in with only minor fettling to the plug) and i sold one to Scott (Sherlock) But his is much brighter making mine look yellow in comparison. Scotts bike had an alarm fitted before he bought it and we figure the extra relays must be the cause. Not being electrically savvy i haven't been able to do the same on mine but if your wanting brighter headlights it might be something to look into.
CYA, Kev.
Toptastic Tip...
Posted: Wed Feb 21, 2007 9:45 am
by Greg
Well, I have been bitten good and proper by the HID bug - I converted my 950 Adv 'S' and was amazed by the difference - it was almost too bright if you could say such a thing! No-one would ride in front of me on our night outings... Just got another kit for the 640 - even cheaper than the first! Bought on Ebay, delivered in 3 days from Japan, a full ISO approved twin H1 conversion - twin ballasts, capsules, all leads etc., to my door for £65.00. Unbelievable how they can do it - but they do !! When the TRX is done, I'll most likely get a kit for that too - if I can figure out where to stow the ballasts...
G :shock:
Re: Toptastic Tip...
Posted: Tue Apr 17, 2007 3:21 am
by devlin
Greg wrote:Well, I have been bitten good and proper by the HID bug - I converted my 950 Adv 'S' and was amazed by the difference - it was almost too bright if you could say such a thing! No-one would ride in front of me on our night outings... Just got another kit for the 640 - even cheaper than the first! Bought on Ebay, delivered in 3 days from Japan, a full ISO approved twin H1 conversion - twin ballasts, capsules, all leads etc., to my door for £65.00. Unbelievable how they can do it - but they do !! When the TRX is done, I'll most likely get a kit for that too - if I can figure out where to stow the ballasts...
G :shock:
Greg,
Any chance of listing the eBay seller so we can check the light set out. Cheers.
Posted: Sun Apr 22, 2007 1:48 pm
by Greg
Heyho... sorry, I missed this post!
The item I bought was:
280082393066 on ebay uk...
this link might work
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0082393066
if not just PM me and I'll give the juice you need...
Posted: Tue Apr 24, 2007 4:02 am
by devlin
Thanks. I also checked eBay in the US. There are a few HID kits on there as well. Mainly set up for R1, R6, ZX, GSX-R etc. but I am sure a twin bulb set up for the R6 would do the trick as they use the H4 bulb.
Posted: Tue Nov 06, 2007 12:42 am
by sherlock
from the Yahoo site:
Projector unit bulbs 40/55Watt – Made only for the FZR RU's.
http://www.mandp.com do stock them at £16.99 each (!?!), Part No: 526016,
Tel:- UK 08705 703030. By the way these units are SOoo good they cost
£368 plus VAT new, Yamaha were ahead of their time, as the car
industry only took up this Excellent technology much later!
