Std Mikuni Carby bowl screw thread size???
Post by cobbadiggabuddyblooo » Sat Jun 06, 2015 1:45 am
I don't have a std set of Mikuni carbies here at present but I have to do a little work on a pair shortly.
Does anyone know the size of the std Mikuni carby bowl retaining screws???
The Phillips head screws can be a right pain in the arse if they are locked in tight.
Same as I'd done earlier with the manifold clamp screws, I want to convert these to cap heads .
Re: Std Mikuni Carby bowl screw thread size???
Post by Con Rod » Sat Jun 06, 2015 5:05 am
m5 *10 or m5 *15, either are good
same for the diaphragm cover
Post by cobbadiggabuddyblooo » Sat Jun 06, 2015 12:09 pm
Thanks Paul,
Is that with a 0.75 pitch??
Post by Con Rod » Sat Jun 06, 2015 1:18 pm
yep standard pitch
Post by cobbadiggabuddyblooo » Sat Jun 06, 2015 2:37 pm
Cool bananas
Thanks Paul
