Bolt kits
petetrx
Bolt kits
Does anybody know where I can get a engine bolt kit? I wanted to repaint the engine and was going to replace the bolts with polished or stainless bolts. Is there a supplier or a list of the bolts somewhere that do this.
- Con Rod
Re: Bolt kits
Best way to go is to just order your bolts, far far far cheaper
I have replaced pretty much every single bolt on the bike with stainless at this stage, just by ordering the sizes I need.
Have a look at this thread
http://www.trx850.com/phpBB_forum/viewt ... ss#p107096
petetrx
Re: Bolt kits
Thanks Conrod, will definitely give them a go. Now to make the list of what to get. Are there any particular sizes which is common on the bike? Thinking I will get a box as the website has got a sale on box buys.
- Con Rod
petetrx
Re: Bolt kits
That list on the other thread, would that cover most of the engine bolts?
Re: Bolt kits
I used zinc plated instead of stainless as stainless has a habit of snapping with little stretch where as the zinc coated steel bolt will yield a little more and you can feel it before it snaps.
If you go with stainless, definately use a tension wrench and set by spec(10Nm on case bolts)
I've replaced most of the engine and frame bolts with cap heads and it makes maintainence so much easier.
Rich
Re: Bolt kits
if you go with stainless also put some copperslip on the threads to stop galvanic corrosion,
http://www.bssa.org.uk/topics.php?article=89
