Headlight - Will this work?
Mav617
Post by Mav617 » Sun Apr 26, 2015 9:44 pm
Hi,
Need help with a headlight question. The headlight below will fit, but does the Uk model TRX have the connectors on the loom to drive it?
SDN
Re: Headlight - Will this work?
Post by SDN » Mon Apr 27, 2015 1:49 pm
Would say so, be similar to the FZR400rr lamp I have fitted to my Rex
Just paralell connect hi, low and neutral into a thre way plastic connector and use brass male and female spades - new plugs and spades are available from Vehicle wiring products - As a piece of advicem do not use the cheap nasty pre insulated connectors you get in Halfords and the like - they are crap - ohh yeah buy a proper crimping tool and for belt and braces solder as well.
Connectors are as cheap as chips and they are posted out PDQ
Post by cobbadiggabuddyblooo » Mon Apr 27, 2015 2:42 pm
+1 on Simon's advice about decent solder, terminals and crimping tool. 8) 8)
A decent crimping tool may cost you $25 or more but money well spent if you do the odd wiring job.
For about the same price for a box of 10 nasty insulated terminals from you local supercheap motor shop, you can buy online 50 decent brass terminals.
Get some M & FM spade/blade terminals and ring terminals and a metre of heat shrink plus your crimping tool for $50 and you'll have most of what you need for a number of years.
Tin the wire and a touch of heat and extra solder once crimped all covered with a little heat shrink and you will have a trouble free insulated connection allowing excellent current flow.
Cover with a touch of dielectric grease once plugged Inplace :wink:
Clips
Post by Clips » Sun May 17, 2015 11:27 am
Where did you source the headlight from and does it throw a good light?
sadmansteve
Post by sadmansteve » Sun May 17, 2015 9:53 pm
Looks like an MZ Skorpion headlight.
Post by Tarwetijger » Mon May 18, 2015 10:25 am
sadmansteve wrote:Looks like an MZ Skorpion headlight.
Yup.
http://www.trx850.com/phpBB_forum/viewt ... 49#p108286
