Time to rebuild my wiring loom and re terminate the mods I have done with better connectors.
I'm also changing the power feed to the coils to work directly from the battery via a relay.
Simple test is to meter the voltage at your battery and then meter the voltage at your coils.
There will be odds on you have a voltage drop and under 12v so your not getting the full potential out of your coils.
There are 4 wires
What I'm doing here is using the original coil feed from cylinder1 as the power to trigger the relay when the ignition is turned on. (green wire and black earth wire attached to relay complete this circuit.)
Cylinder 2 original coil feed I will use as the trigger on a 2nd relay for my O2 sensor set up.
( you don't need it just tape it up or you can use it as I have for an accessory feed)
So when triggered this opens the circuit to draw power directly from the battery through the relay to the coils (shorter heavier red cable and the longer heavier red cable coiled up with the Y split to feed both coils attached to relay)
The result being a stronger spark
The relay I have chosen to use has added protection with a built in fuse from the battery feed and the original cylinder 1 ignition feed used to trigger the relay already runs through the original TRX ignition fuse in the fusebox so there is protection for both feeds to the relay.
Heavier 15amp cable is used on the battery/coil feeds and all connectors are crimped,soldered and then heat shrink for insulation.
I will be mounting mine under the front section of the R/H side cover beside the battery tray.
I'll be making up another 3 so if anyone wants one ($30 shipped in Oz) send me a PM.
I've used ring terminals not spade terminals on my coil feeds due to the Dynatek coils and the others I make will have insulated spades to suit the std TRX coils.
The green wire will have a blade terminal to connect to the original wiring harness so everything plugs straight inplace on the std TRX loom and coils.
Ring terminals are used for the battery feed and earth.
I will be taking my battery feed straight from the battery side of the starter relay.
You can easily remove the fuse from the relay as an added anti theft device too.
So if they know how to Hotwire the std ignition switch, this will slow them down why they trace why they still have no spark.
