Has this been done before? Does the trx oil pump have enough pressure for a turbo? I know the preferred method is to use the carbs as a blow through setup but that looks very complicated, i was thinking more of putting a mukini 38mm carb on the turbo and do the suck through method?
Any one have any input on this idea?
Has anyone tried a turbo conversion?
reefer24131
Bandit 600,bandit 1200, x2 crm 250, drz 400, xr650r, thundercat 600, x2 trx 850, honda cbx1000 6cyl and a supercharged gilera runner 210
Re: Has anyone tried a turbo conversion?
http://www.trx850.com/phpBB_forum/viewt ... f=5&t=4087reefer24131 wrote:Has this been done before? Does the trx oil pump have enough pressure for a turbo? I know the preferred method is to use the carbs as a blow through setup but that looks very complicated, i was thinking more of putting a mukini 38mm carb on the turbo and do the suck through method?
