I'm having difficulty getting a set of TDMRs and can't afford a new set.
R1 40mm carbs
R1 40mm carbs
Has anybody thought/tried fitting R1 40mm carbs to their engine?
- ge0ff
Re: R1 40mm carbs
I'd be curious to see how you get on with this.
I'd love to open the ole girl up a bit but the FCR's are a big chunk of cash.
Re: R1 40mm carbs
What I don't get is that a lot of car boys use them on Ford/Volvo engines as sidedraught carbs but they're downdraught on the R1, like the TRX
- ge0ff
Re: R1 40mm carbs
I'm a child of my generation unfortunately - stripping and cleaning or re jetting, no worries. But trying to do something like this, just making it up as I go along.....id probably not get very far.
Have a go and let know how it turns out lol
- Con Rod
Re: R1 40mm carbs
dandywarhol wrote:What I don't get is that a lot of car boys use them on Ford/Volvo engines as sidedraught carbs but they're downdraught on the R1, like the TRX![]()
hmm might be an issue setting float heights there
- SDN
Re: R1 40mm carbs
wonder what that does to power / fuel consumption
NWS870R
Re: R1 40mm carbs
You could buy a full set of brand new YZF750 FCR41's for the same price as a pair for a TRX (£800ish) & split the cost between you? Just a thought?
Re: R1 40mm carbs
A good idea NWS - thought of that one before but is there not just one pumper feeding 4 carbs?
I've been down that road earlier with TDMR40s - someone had split a set of 4 and muggins here bought the pair without the pumper - luckily the German seller took them back and paid the post back..................
NWS870R
Re: R1 40mm carbs
All parts/spares are readily available & it's still cheaper than £900 for a TRX specific kit?
Re: R1 40mm carbs
OK thanks - I'll look into it. Are the FCRs jst the one pumper and a fuel link to the other carbs?
Could you then fit a pumper pump/linkage etc. to the remaining pair if split up?
PS, answered my own question - the FCRs appear to have twin pumpers, one per pair as opposed to the Mikuni TDMR which appear to have only one pump feeding 4 carbs
NWS870R
Re: R1 40mm carbs
,NWS870R wrote:Kerching!!!!
Ok, ok - it takes a bit of time til the penny drops at my age - life's still a big learning curve
bagmaker
Re: R1 40mm carbs
I purchased a set of 39fcrs from a kwaka 750 drag bike (USA ebay) and the set only had one pump.
That said, no big deal to get another pump happening from parts
those who can count
and those who cannot
those who can count
- Kayla
Re: R1 40mm carbs
I split a set of R1 carbs to fit on a TRX a few years ago for someone. There was only one pump on them and it was only the centre pair that were used as they were spaced right to fit the TRX from the start, meaning the two 'end' carbs were spare.
If you decide to split a bank of R1 carbs into two, splitting them down the centre into pairs, you'll need two new throttle rods as they're machined to suit the spacing of the carbs. Maybe Allens could supply them, I don't know. You'd also need new ally spacers and blanking plugs.
It's doable but I think it'd end up being an expensive PITA.
Re: R1 40mm carbs
Thanks for your input folks - all invaluable................
