I was having the same issue & so went & bought some leds from super cheap, not a single globe blown since.
The dials are much easier to read & for the tacho I had a blue for the start & a red near the end so gave that going into the red/pink vibe.
Only issue is because they create almost no heat they won't help clear any fogging if you get ant inside the bezel
LED instrument cluster lights
