Trx cafe racer.
Posted: Sat Jan 03, 2015 12:19 pm
by hendocdog
Any body have any advice on fitting upgraded running gear to the TRX. I have R1 running gear in my head and have purchased a 5vy swing arm as I prefer the 5 spoke wheels but there is an off set in the swing arm so I may have to re-think. Any advice on swing arms you guys have fitted.
Re: Trx cafe racer.
Posted: Sat Jan 03, 2015 12:29 pm
by dicky
Some FZR front ends bolt straight in.
YZF front ends can be made to fit.
Similar with back ends.
We've even seen single sided VFR back ends fitted.
One recent build was with Aprilia front and back, including spoked wheels.
Where in this big wide world are you?
There may be someone close by who would be willing to show you what they have already done.
Saves a lot of head scratching.
Re: Trx cafe racer.
Posted: Sat Jan 03, 2015 12:57 pm
Shame you weren't onboard late last year. Pair of Marchesini 5 spoke wheels where up on offer.
I modded a wider yzf 750 wheel 3 spoke to fit the std swinger as have a few others ( even tho i never used it and just purchased a pair of Dymag SB5's instead)
I'm sure you could easily do the same with a later 5 spoke rear wheel with matching R6 or R1 front end. It's an easier way to keep sprocket alignment and excellent geometry of the trx. Nothing wrong with the stock swing arm and if you want the tough look just weld the bracing in place. Not that hard and a cheaper option if you want the bling factor and added weight.
Re: Trx cafe racer.
Posted: Tue Jan 06, 2015 10:47 pm
by hendocdog
dicky wrote:Some FZR front ends bolt straight in.
Thanks dicky. I'm in Newcastle upon tyne. I've done some more measuring and the 05 swing arm should fit with some mods. But anymore advice is appreciated.
Re: Trx cafe racer.
Posted: Tue Jan 06, 2015 10:50 pm
by hendocdog
cobbadiggabuddyblooo wrote:Shame you weren't onboard late last year. Pair of Marchesini 5 spoke wheels where up on offer.
Yeh I thought about that option but I have my heart set on the 05 r1 running gear. Il post some pictures soon enough. Thanks for advice. I haven't bought wheels yet so if some come up just shout.
Regards kev
Re: Trx cafe racer.
Posted: Wed Jan 07, 2015 10:34 pm
by phil108
Oh up my neck of the woods then !!! Nice to hear of someone local :D
Re: Trx cafe racer.
Posted: Thu Jan 08, 2015 11:24 am
by coxylaad
and mine!
The R1 swing arm is a lot longer than the TRX one, and will most certainly have an effect on the bikes handling.
The easiest option is the YZF 750 arm, but its not to everyones tastes. I fitted a thunderace rear arm to mine, its in keeping with the original but better finished and beefier.
Check my thread out http://www.trx850.com/phpBB_forum/viewt ... f=6&t=6637 that has the entire build on my bike on there.
