Dyno time
- SDN
Dyno time
Booked some dyno time for tomorrow so should find out how near (or not) my carbs are. Also have been experincing a bit of clutch slip in higher gears at full throttle. Checked clutch adjustment, which is fine so am thinking it is down (hopefully) to more power!
Have ordered an EBC sintered carbon clutch kit, which should hopefully cope with the extra power.
I have also ordered an alternator cover gasket and will remove that cover and respray it as it is looking a bit tatty.
I know the question has been asked but what silver engine paint would you guys recommend?
NWS870R
Re: Dyno time
I used Hycote high temp in aluminium colour which is a very good match to original. Make sure you lacquer over the base coat with a petrol resistant clear coat - i didn't & ended up doing the job twice!
Good luck with the dyno time m8
Trxdick
Re: Dyno time
Where did you book your dyno if you don't mind me asking , do they have a tech there to help out with fueling/mapping ? I need to set up brand new fcrs and programable ignition shortly and have no idea where to go . Have heard some sorry tales of expensive cock ups and dyno disasters !
- SDN
Re: Dyno time
I went to a place in Cannock, they charge £45 for a couple of runs and some advice on jetting and settings. Mine came out pretty much spot on a tiny bit rich on full throttle main jet and a tiny bit weak on the pilots and actually can you can feel the pilot wants a bit more.
NWS870R
Re: Dyno time
You didn't go to Craig then m8?
- SDN
Re: Dyno time
Hi Chris - he was too busy - couldn't get a date of him. still like to leave it with him to tweak (yikes typed twerk- but luckily spotted it!)
- SDN
Re: Dyno time
Place in Cannock was called PCR performanceSDN wrote:I went to a place in Cannock, they charge £45 for a couple of runs and some advice on jetting and settings. Mine came out pretty much spot on a tiny bit rich on full throttle main jet and a tiny bit weak on the pilots and actually can you can feel the pilot wants a bit more.
Re: Dyno time
How did you go output wise at the rear wheel Simon?
Must be close to 90hp/ 67 ft/lb.
At what rpm did you find max torque if you don't mind me askin?
- SDN
Re: Dyno time
Sorry cobba been away, my scanners up the creek at the moment so can't scan chart, will dig it out when the dust settles from hols
