the final update.. where to begin..
Id like to state before anything, this will prolly always be a "ongoing" mod.. Ive got MUCH more to do after ive discovered some things from riding it (yes i ride it now, more on that soon). I still have my entire spare TRX900 motor which i will focus on more now, to get it finished and fitted.. Im still unsure about carbies / injection, but either way i go, be sure to drop in and have a look, ive got a choice and design for each, so wait and see which direction i head.
Im now running a 17t / 43t in a 530 series (o-ring) chain.. This wasnt the easiest of conversions.. I had to get my old 17t, machine the gears off it, thin it down a bit, and use the internal spline part as a spacer.. I then machined the spline part out of the new gear, and welded the 2 together. Yes i lined them up.. i made a jig actually.. anyway, its more dished now.. I did this because the R1 rear wheel was wider, pushing the chain out more. And because there was no 525 conversion for the R1 sprocket, i could only make the front suit.. luckily there was a 530 conversion.. woot me.
Ive also put on a renthal 43t lightened alu sprocket.. Its actually bolted on backwards as to pull the chain close in by ~5mm or so.. every little bit helps here.. its surprisingly straight and is smooth.
Brakes are shuddering a bit.. Need to clean the rusty spots off them.. its my own fault
Bike handling feels "crisper" than im used to.. but after being on a limo and now this, its much better. There is a pic to show how i shortened the swinger and how it looks in the bike now.. hope you understand.
Well, here it is.. In its "finished" state.. im happy.
This shows my attempt to tidy up the wiring, and you get a fairly good look at how the front end actually will pull off via "R" clips.. ive got them attached to rubber bands.. im going to use thin metal wire (think guitar wire) and clamp em to the frame somehow.. so i dont loose em.. bastard things.
Forgetting the rust on the disks and the dodgy paint on the guard, you can see on the upper red circle, the speedo pickup, and the lower red circle is the magnet than it senses as the wheel revolves aronud.. works perfectly.
Ignoring the water stains (yes i need to rebuff it.. get over it) you can see how the red lines show where the new plate is, and how i cut it.. the blue line is the line it took previously.. basically by doing what i did, it shortened 72mm.. or was it 73... either way.. around there.. works well. is VERY tight in there now.. very little room for much of anything.
I took it for its maiden voyage today... fired it up, worked well.. went to take it out,, got up end of street and im "err.. this seat is low.. VERY low" so turned around, stationary, bounced up and down.. i could bottom it out
rode home.. checked it out.. id set my adjustable dog bones to "low rider" status.. tightened em up, set my rebound rate to 11/11 clicks, meaning there is basically no resistance on the oil in the shock, the bike will rebound fast.. set it 1/11 clicks, and it comes up VERY slow.. i wanted more response to feel what was going on.
Reride the bike.. still not perfect.. still a bit too "soft".. go back, check coil, its set to "omg im a small chick" compression.. i CANT stiffen it up as yet. i dont have the correct tool to rotate the lock nut.. Ill do that tomorrow i hope. set it to hardest and work my way back... since im a bit larger..
Front brakes give a slight shudder, but got better over time. ill clean disks n pads and re-asses..
The smoothness of the ride is amazing now.. i feel comfy in the position i set.. I lowered it ~20mm from stock TRX seat to lower centre of gravity aswell as change my riding position.. I feel more "relaxed" now.. bars need to be adjusted tho.. which will prove a BITCH... as you may notice they are welded.. /me slaps head.. BAD BOY
the 43t sprocket is a weapon.. the front is SO wheel happy now.. it just launches when you want it to.. its jsut scary if you want it to be. and thats with a soft spring.. imagine it will be uber with a hard setting.. i cant wait honestly !
Well, thats about it kids.. journey ends hear.. Sure ill update things here and there and answer any questions on it / help ppl.. but im not gonna be submitting many more pics on this unless asked.. or trying to explain somethin.
Might show when the bike is painted or track day or somethin.. wait and see..
Just a note.. by this time next year.. the bike will be different again.. Scary as it is, i have plans.. and they aint small.. what ive done is nothing to what i WANT to do.. but im gonna ride it for a few months before i de-commission it again for another rebuild..
hint: think new engine and... other things.
