TRX900special
Re: TRX900special
Post by misterdimwiddy » Sun Apr 21, 2013 7:53 pm
I love it.
Don't usually go for cafe racer conversions but this looks stunning.
My own level of creativity falls way short of this project.
Congratulations on such a quality build.
zednine
Re: TRX900special
Post by zednine » Sun Apr 21, 2013 9:05 pm
A superb creation you should be rightly proud =D> =D> =D> =D>
Stu99
Re: TRX900special
Post by Stu99 » Sun Apr 21, 2013 10:50 pm
Beautiful build, really clean and all the lines are good. Top work, you should be very proud of that. =D> =D> =D> =D>
Saved that one to my photo library of favourite bikes, hope you don't mind. 8)
spondontrx
Re: TRX900special
Post by spondontrx » Mon Apr 22, 2013 2:18 pm
Thanks everybody :D I did the first serious ride with it yesterday, and everything work't fine (and almost nothing fell of :lol: )
The cockpit is this one : http://www.louis.de/index.php?topic=art ... r=10034806
And the headlight can be found here : http://www.japparts.nl/index.php?main_p ... s_id=11766
And some more pictures :
Re: TRX900special
Post by Yoozy » Mon Apr 22, 2013 3:03 pm
What is the exhaust ?
spondontrx
Re: TRX900special
Post by spondontrx » Mon Apr 22, 2013 5:55 pm
The 2 in 1 headers I found on this forum :) http://www.projection-components.co.uk/ ... -168-p.asp , and the silencer is from Lazer (stealth)
Re: TRX900special
Post by dandywarhol » Mon Apr 22, 2013 10:18 pm
Lovely job - and the satin yellow just finishes it off.
Is that a TDM9 rear shock?
spondontrx
Re: TRX900special
Post by spondontrx » Mon Apr 22, 2013 10:50 pm
The rear shock is from a 2005 zx6r witch was an easy fit , but I found out during a long ride that it needs a lighter spring :roll:
Re: TRX900special
Post by Con Rod » Mon Apr 22, 2013 11:27 pm
spondontrx wrote:The rear shock is from a 2005 zx6r witch was an easy fit , but I found out during a long ride that it needs a lighter spring :roll:
Not sure if this would work on a stock trx as the shock reservoir may foul the reg/rec. But then moving the reg/rec would be simple enough
ScHisM
Re: TRX900special
Post by ScHisM » Sat Jul 20, 2013 1:32 am
Wow. Just wow. :shock: Beautiful.
monaro_77
Re: TRX900special
Post by monaro_77 » Sat Jul 20, 2013 8:48 am
Awesome bike its just so different I love it.
QuickDraw
Re: TRX900special
Post by QuickDraw » Sat Jul 20, 2013 1:17 pm
Hats off to that one... original thinking that retains and enhances the TRX character.
Thanks for the link re the exhaust too... interesting!
Re: TRX900special
Post by cobbadiggabuddyblooo » Sat Jul 20, 2013 1:46 pm
8.5HP is a bit of a bold statement everywhere just from the exhaust system.... A stock TRX puts out 76hp so another 8.5 will get it close to 85hp.. I can show dyno results of gaining just on 6 HP from a carby rebuild and just getting it all set up right (from 70 to 76hp) and I would believe 2 to 3HP from the pipes on the top end. A 44mm header would rob you of some of that midrange. I gained 2HP from the large bore 2 into 1 from pipemasteres with incremented header diameters with 44mm coming into play around half way between the first two bends...and then 50mm after the collection box...
Gordo
Re: TRX900special
Post by Gordo » Mon Jul 22, 2013 7:35 am
Excellent work! Looks fantastic. =D>
My curiosity begs... have you weighed it? :)
Gordo-
Re: TRX900special
Post by coxylaad » Mon Jul 22, 2013 10:58 am
That is one of Kayla's exhausts, she is a regular on here.
The 8.5bhp was done on a dyno, with a before and after installation.
I have seen the printouts, it is what it is!
