ZX10R Shocker
Richy
Re: ZX10R Shocker
A quick look, TRX 202kg wet, ZX10R 196kg wet............
jjmoto
Re: ZX10R Shocker
Has anybody successfully done this conversion & does it work?
- Mav617
Re: ZX10R Shocker
I'd be interested to hear if this has worked also without mods to swing-arm or shock?
Re: ZX10R Shocker
Only zx10 shock that comes remotely close to the TRX specs in length and stroke is the 08-10 with a 64mm stroke (TRX 62mm) and about 8mm shorter than the 345mm TRX shock.
07 zx6R is withing a few mm too.
Then look at swing arm length and the rising rate suspension ratios and your damping could be anywhere.
- brockzila
Re: ZX10R Shocker
I have a Zx10 shock in the shed and as I was stripping my Trx I test fitted the Zx10 shock as a trial and it fitted in with out a problem. I measured the fright difference and it was not much. The Zx10 also has an asgustable too shock mount so I think mt plan was to mod this slightly with a 10 mm longer threaded stud to get the shocks to the same length.
Is it Brock friendly???
Trixed
Re: ZX10R Shocker
Hey Brockzillabrockzila wrote:I have a Zx10 shock in the shed and as I was stripping my Trx I test fitted the Zx10 shock as a trial and it fitted in with out a problem. I measured the fright difference and it was not much. The Zx10 also has an asgustable too shock mount so I think mt plan was to mod this slightly with a 10 mm longer threaded stud to get the shocks to the same length.
What year shock is that. Also a pic would be great.
Thanks
ac@39
Re: ZX10R Shocker
Aye up.. Spill the beans .. Which year ? Sounds good as I am putting in a modded aprillia swing arm and like the idea of adjustable top mount , as have no idea as yet where my ride height will end up as a resultbrockzila wrote:I have a Zx10 shock in the shed and as I was stripping my Trx I test fitted the Zx10 shock as a trial and it fitted in with out a problem. I measured the fright difference and it was not much. The Zx10 also has an asgustable too shock mount so I think mt plan was to mod this slightly with a 10 mm longer threaded stud to get the shocks to the same length.
inspired by san miguel
- Mav617
Re: ZX10R Shocker
Have bought an 03 ZX6R shock, going to give this a go. It's about 5mm shorter than the TRX one, but has a stroke of 72.5mm - is that going to be a problem does anyone think?
Re: ZX10R Shocker
The stroke is the one measurement you want to keep as close as possible to the std TRX.
130mm rear wheel travel std on a TRX and the relay arm, swing arm/dog bone pivot point and lengths dictates the rising link suspension ratio, so 130mm std TRX travel works out to your 62.5mm stroke of the std TRX shock using the std TRX swing arm, relay arm and linkages.
your only using around 80% of the shocky's stroke so you will find the damping and spring rate way to soft and you will only loose by fitting it.
- Mav617
Re: ZX10R Shocker
Thanks Cobba, will sell on to the SV650 boys then!
- Mav617
Re: ZX10R Shocker
Ebay wouldn't ship it from the US, so I got a 2009 one from the UK instead - stroke 64.5mm so much closer to the TRX one, length 335mm so got a jack up kit as well.
sjones95
Re: ZX10R Shocker
How did this conversion turn out?
- Mav617
Re: ZX10R Shocker
It didn't - the ZX6R (2010) shock had a top mounted reservoir which fouled the reg/rec - in the end I got my TRX one rebuilt/regassed.sjones95 wrote:How did this conversion turn out?
sjones95
Re: ZX10R Shocker
Cool - Thanks Mav,
Should I presume there is very little that will swap straight in then?
Thanks
Thanks
- ricr378
Re: ZX10R Shocker
yzf750 shocks fit in but need a jack up kit from kayla to get the ride height back. R6 shocks also fit with an adapter from kayla at projection components as they are a bit short. plenty of examples of them on here if you do a search.
