I swapped out the original calipers for blue spots and changed to braided stainless hoses. The brakes were still very spongy and it turned out that the master cylinder wasn't in the best of health - Yamaha do an overhaul kit for it, which made the world of difference to my brakes (i.e. I had some!).boyso20 wrote:yep top off master cylinder but still soft as. will try to pump it for a few minutes, then on its side and hopefully sort it out. bloody annoying!
Fitting Blue Spots is EEEEASY
Dee
Dee
R1 calipers will also be a straight swap, as the bluespot R1 and R6 calipers are exactly the same. In fact, I've got blue spots from a '98 R1 on my bike.
What WON'T fit, BTW are the later gold spot calipers, (although I think very early ones will fit - but it's not worth paying out and taking the risk).
dirty trix
Pity - I can get gold spots easily and they'd be better bling - the colours fit the gold/black of the bikeDee wrote:R1 calipers will also be a straight swap, as the bluespot R1 and R6 calipers are exactly the same. In fact, I've got blue spots from a '98 R1 on my bike.
Dee
dirty trix
Peter850
- bobtrx
you all talk of changeing the calipers , when I changed mine to blue's I also changed the mastercyclinder\brake lever . I 've heard where not changing the master won't give as good as result ( I maybe wrong ) so if some one is looking to up grade maybe we should say change complete not just the calipers
catch ewe later bob
I've done this on 3 TRX's of mine now.
The first 2 I used the TRX master cylinder and hoses. No problems, felt great, brakes braked etc.
On the current bike I put braided hoses on and found that the stock master cylinder was too much. No feel, very on/off brakes. Fitted a 14mm master cylinder from a ThunderCat and all is well.
I think the hoses are the deciding factor.
