Fitting Racetech Gold Valve cartridge emulators
Re: Fitting Racetech Gold Valve cartridge emulators
Post by cobbadiggabuddyblooo » Mon Jan 14, 2013 12:14 pm
So by increasing pressure on the spring on the emulator does that increase the damping????? The description on one of the original posts only says to alter the compression increase the pressure on the spring????
Post by Con Rod » Mon Jan 14, 2013 12:25 pm
cobbadiggabuddyblooo wrote:So by increasing pressure on the spring on the emulator does that increase the damping????? The description on one of the original posts only says to alter the compression increase the pressure on the spring????
yes,
details on how they are supposed to work is here:
http://www.racetech.com/page/title/Emul ... hey%20Work
Post by Mincehead » Mon Jan 14, 2013 9:49 pm
Great read, cheers for posting that. ;)
Post by Con Rod » Tue Jan 15, 2013 1:46 am
got the emulators finished last night. after filling them both and polishing them and have them to within 0.03mm of each other
Post by cobbadiggabuddyblooo » Tue Jan 15, 2013 8:00 am
Well done =D> thanks Paul . The Promech emulators I have in one set of forks are non adjustable and you can feel the improvement but I've just picked up another pair with g/ valves fitted so this helps in understanding in setting up. I think I'll use a common pair of fork springs as a starting point and go from there as I know how the Promecha feel...
