If i was to fit the R6 rad I have, I was going to make up a rubber lined C bracket with a mounting tongue to fit around the radiator tanks on either side for the fairing/rad bracket.
No need to solidly fix the C bracket to the radiator as it's purpose is to stop any front/rear horizontal movement and would easily manage that via it's shape.
I'm finding even with the oversize bore and higher compression, temps are still running as per std and has never gone over 96*c with the lower thremo fan switch. I can prob see the R6 rad just gathering dust with the oil cooler I have too.
What's next?
Re: What's next?
- SDN
Re: What's next?
Got the R6 rad for £28 all in with fan off flea bay, so seemed worth a punt, C brackets would work but I suppose you would still have to fix brackets to tongues which might look a bit messy. I am also quite intrigued about low temperature aluminium brazing. I was once a production engineer for Aeroquip and we did a lot of aluminium brazing for auto air con components
- SDN
Re: What's next?
Plus brazing would give me a great excuse to purchase a really nice brazing torch - coz like I really need one!
Re: What's next?
- SDN
Re: What's next?
Blimy looks bloody close to front wheel!
- SDN
Re: What's next?
Well Front end is now bolted in place with spacer and R1 5PW yokes. It all went together very well, just waiting for a few more parts so I can take it out. Will be baby steps at first, but as I am really just getting geometry back to standard TRX with usual dogbone / lowered forks, I can't see it should do anything terrifying.
But it would be a shit to fall off prior to the Majorca Trip with Karate Club - stating 4th May
The Club out for Dan Grade Training
