Progressive Springs
- burty
I fitted mine in blind faith. I don't recall any real difference in length, not so as to cause me to question anything. I didn't do a direct comparison though.bevie wrote:Hi Burty,burty wrote:Which brand of springs are we discussing here?
I don't recall any problems with the length of the Hagon springs.
Yes they are Hagons.
How much is a bit shorter?
bevie
Burty,
About 25 / 30 mm shorter I have talked with the Hagon rep and say's this is correct and no need to worry , no extra spacres needed either ,thanks for all the input guy's
will let you know how I get on when I finally get back on the road still too much salt and grease up here at the moment " and still a good chance of snow "
Thanks again,
Ian.
Thanks again,
Ian.
dfh
Hey Bevie.. put the springs in yet? Can you set the sag without braving the ice'n'snow?bevie wrote:Burty,
About 25 / 30 mm shorter I have talked with the Hagon rep and say's this is correct and no need to worry , no extra spacres needed either ,thanks for all the input guy'swill let you know how I get on when I finally get back on the road still too much salt and grease up here at the moment " and still a good chance of snow "
Thanks again,
Ian.
DFH
bevie
DFH
Fitted the springs but not been out yet busy trying to get my old Honda 550 F1 ready for showing at the Scottish Motor Cycle Show in March will let you know when I finally get the TRX back on the road
Cheers Bevie.
arrivisto
Re: Progressive Springs
I'm a 95kg rider and my current TRX's forks are too bouncy, and need better springing and damping. I have considered Hagon or Wirth progressive springs, but ideally, I would prefer straight-wound springs and Race-Tech Gold Valves. Having done a bit of research and having watch the YouTube demos, I think Iwould rather have a dealer do this, even if I have to take the forks off the bike myself. So the question is: is there a bike professional in the UK who can do this? Answers on a postcards, please!
- highlander
Several in the UK, look at
http://www.shocktech.co.uk/race-tech.html
http://www.stevejordanmotorcycles.co.uk ... oductid=43
among others .... it's just drilling the damper rods, most decent mechanics should do this cleanly!
