by trixynut » Thu Apr 05, 2012 11:03 pm
This is my dyno curve from my old bike which had bigbore 2 into 2 system with freeflowing cans and FCR carbs on a standard engine, just like yours.
Chart doesnt show RPM unfortunately, but the big drop-off in each gear is where it hits the limiter, so you can see you should have a pretty linear power delivery in each gear, but best torque and power is up to 7.5k rpm like KW says.
winder
by winder » Sat Apr 07, 2012 7:51 pm
Hi, i have spent the past two seasons racing a TRX in UK Thuderbikes (have a look at TRX Eligible For BEMSEE Thunderbikes in the Bike Racing section on this forum). A couple of quick fixes would be gearing, i used 15-42 at Cadwell and the extra breather mod made it rev up to the limiter quicker. P.S. you should be racing it in Thunderbikes where it will be more competitive
winder
by winder » Sat Apr 07, 2012 7:58 pm
Another pic before the big Snett blow up!
