Bad piston
Very bad pin
Very sad con rod
Bad design by Yamaha
Are they a quality moly bit or a regular repco/supacheap one?brettmcgaw wrote: I've buggered 2 bits and most of the screws from the balance shafts
First one was in a Kinchrome set. Second one was a $10 Repco job (came in a 3/8 socket). They both twisted. I ground the Repco one shorter and seated it better with a hammer, but that only helped with the Balance Shaft retainers. For the Gear Cluster retainers (punched screws), I put the casing on its side and had my full weight and a pipe on the handle of the driveAre they a quality moly bit or a regular repco/supacheap one?
Did you drill out the punch/locking marks first? Unless you have the screws are not going anywherebrettmcgaw wrote:First one was in a Kinchrome set. Second one was a $10 Repco job (came in a 3/8 socket). They both twisted. I ground the Repco one shorter and seated it better with a hammer, but that only helped with the Balance Shaft retainers. For the Gear Cluster retainers (punched screws), I put the casing on its side and had my full weight and a pipe on the handle of the driveAre they a quality moly bit or a regular repco/supacheap one?... nup. Wrecked the screw. Maybe Trade Tools at Nambour will have something.
And an m16 in .223 cal, in a hunting stock..trixynut wrote:Interesting thread this, keep it coming.
Taking motors apart is good fun isn't it?![]()
As an aside, that's an interesting bike Mr Thompson is astride. A Penton, small capacity MXers with Puch engines and KTM parts, built from 68 to 78.
Anyway, as you were.....
Ah. No. I was thinking the punch was just a little anti-vibration measure-Did you drill out the punch/locking marks first? Unless you have the screws are not going anywhere
