Ok, gent and ladies, i have just rebuilt my carbs and was shocked at the amount of crap in the carb on the lower side of the piston diaphragm
This is fed by the two large dia tubes, these have a course mesh filter to keep out the bugs and that's about it! i would not normally be concerned about these thing, BUT, this crap gets trapped on the slide and aides in the overall wear and tear
there is also a small (1.4mm) pilot air jet in here that could easily be clogged up with crap
NOT happy Jan!
Look at the crap!!
All comes in through here!
Not what i would call a filter
My initial solution….stoped the tank from seating
Two crankcase breathers, and shortened tubes, works well and they sit against the rubber tubes so no noise or damage!
Again i forgot to take a finished photo
