Hi Folks,
I'm assisting my old mate to do a front end conversion on his 1996 TRX; Current we have replaced the top yoke, fitted renthal bars and also fitted headlight fairing brackets.
The clocks on the bike are a little wide for the raptor style fairing he has bought; any suggestions as to what gauges to buy that would directly plug into the existing loom?
Rsvp, Phil.
Replacement Clocks
- MadAd
Re: Replacement Clocks
If your looking for narrow clocks look Buel but I doubt they are a direct plug in!!
Can't think of anything that would just plug in that is not the same size or bigger than you already have!!
Would be interested to here if you manage to sort anything.
You may need to head down the rout of buying after market enduro digital type of clocks!!
phil_inglis
Yeah, it may mean we need to take the gauges out of their housing and make up a alloy dash for them to fit in.
Thanbks for the reply!
- Bullet
Don't know for certain but wouldn't an early R1 digital clock work, as this is the front end most TRX's change to?
I'm addicted to brake fluid, but I can stop anytime.
- fung
don't R1 digital run off the countershaft sprocket?
- sadmansteve
