Fitted pod filter?
Posted: Mon Feb 06, 2012 3:48 pm
by MadAd
Any of you that have fitted pod filters, what did you do with the engine breather pipe?
p.s. the filters I'm looking at don't have a hole in the bottom for poking the pipe through.
Re: Fitted pod filter?
Posted: Mon Feb 06, 2012 4:49 pm
You can either cut a hole in the filter to route it through there or you can do what I did which is put a small filter on the end of the pipe.
Posted: Mon Feb 06, 2012 5:32 pm
more info here (a bit of a blast from the past!)
viewtopic.php?f=6&t=811&p=7556&hilit=cr ... ther#p7556
Posted: Mon Feb 06, 2012 10:55 pm
by MadAd
Had a read through the thread thanks.
Will look at poking the breather into the filters!!
