Woo fooking hoo - 102.3 bhp !!!!!
Post by phuk72 » Fri Oct 27, 2006 7:24 pm
Just got back from getting my bike dyno'd. Peak power was 102.3 bhp 8)
My scanner is fecked at the moment so I'll post charts next week at work but the curve is a thing of beauty :D :D :D .
Ran it back to back with and without TPS and can tell you that disconnecting the TPS gives more power right the way through the range (approx 1 - 2bhp) and a bit more torque (again right the way through the range). Peak power with TPS connected was 100.7. That said, it's a bit lumpy under 4,000 and is noticeable on the road.
I also got down there before fitting the flatslides and got a peak power run of 92.1 (TPS connected) so can confirm that FCR41 with K&N filters are worth a power hike of over 8bhp. Not quite the 11 promised by Brett ( :wink: ) but still a hell of a lot more than I was expecting and perhaps the best bhp per pound mod you can do.
The most interestign chart have 3 runs over laid - CV vs FCR vs FCR (no TPS) - and I'll get this up asap.
Re: Woo fooking hoo - 102.3 bhp !!!!!
Post by Killerwhale » Fri Oct 27, 2006 8:01 pm
phuk72 wrote:Just got back from getting my bike dyno'd. Peak power was 102.3 bhp 8)
Nice!!
What specs have you landed on the jets/screws of the FCR´s?? I guess we got quite similar climate in UK vs. Swedish west coast....
Post by phuk72 » Fri Oct 27, 2006 8:05 pm
Nice!!
158 jets - needle 3rd clip from top
Post by Killerwhale » Fri Oct 27, 2006 8:16 pm
phuk72 wrote:
Nice!!
OK! So i guess i will try 160 on the left and 165 on the right then.
Also think that the 41´s for TRX are set to 4th groove so i´ll try lower the needle.
No tweek in needle taper, slow air, fuel screw then!?
Post by phuk72 » Fri Oct 27, 2006 8:18 pm
Nope
jpe
Post by jpe » Fri Oct 27, 2006 11:20 pm
Please Mr Santa Claws, can I have a pair of FCR 41's too...? :cry:
Btw, well done Pete! Who needs a 999 cc L-twin anyway :D
"There is no spoon"
Post by trixynut » Sat Oct 28, 2006 12:03 am
Nice one Pete!!
Told you the tps mod I figured out was worth doin'! 8)
Dave
Post by Killerwhale » Sat Oct 28, 2006 8:29 am
trixynut wrote:Nice one Pete!!
Dave
May be an idea to put the mod out here on the new forum also, nice "tip/trick"!
punica78
Post by punica78 » Sat Oct 28, 2006 9:12 am
That's not a bad result at all Phuk! I'm really curious after the dynochart...
=D> \:D/ [-o< :thumbleft: :headbang:
5 May 2006: Zolder
2 September 2006: Folembray
"Fortitudo. Disciplina. Constantia. Patientia. Contemptus Mortis. Amor Gloriae. Amor Victoriae!"
honkdawillydahonk
Post by honkdawillydahonk » Sat Oct 28, 2006 9:22 am
Holy Funk! Well done that man! My lowly 99BHP looks a bit sick now.... I'd better get working on that ram air! Was that measured on Grant's Dyno?
Post by phuk72 » Sat Oct 28, 2006 10:24 am
Yep, that was with Grant.
not actually done that yet, this was just with the TPS pulled off carbs. will be doing it now but designing some sort of switch so that I can go between the 2 (need to do more testing but TPS is deffo better for road)
Post by phuk72 » Sun Oct 29, 2006 1:31 pm
burty
Post by burty » Sun Oct 29, 2006 9:22 pm
I want some FCRs.
What's the point of the TPS again? Yes timing advance but what is the benefit of the variation in advance, can you tell?
Post by phuk72 » Mon Oct 30, 2006 9:20 am
With TPS there is much less 'surging' at lower revs (4k or less) and when on half open throttle. Not noticeable over 4k really.
Janitor
Post by Max » Mon Oct 30, 2006 11:25 am
I guess TRX HP figures are kinda like bowling scores... Happy if you break 100, pissed if you only get a 99... :wink:
