Time for an update. I got all the parts back, so it's now just a matter of getting it back together... which is easier said then done of course.
The crank is back in place. Quite a job to make the timing with the balancer shafts correctly, but I managed.
I had to buy an other set of cilinders, because the old ones were a little oval. The pistons were allright though.
I'll be using the original cylinder head. It appeared that the spare head I already had, was even worse.
The guys who fixed the crank also had a go on the cil.head, the cams move smoothly again.
Here's a funny shot of the exhaust valves, they were all bent.
One of the bolts of the oil reservoir was broken. A small piece of it was still remaning in the bolt hole. I got the engine to the local garage (where I always bring in my car), but they didn't want to help me. I borrowed a tool, for which I don't know the english name, but it worked!
I think that oil was closed in by the bolt when it was put on earlier on. Before my time anyway because the remains of the bolt just dropped out when I was working on the engine.
