change gear ratio
zakisbak
change gear ratio
Post by zakisbak » Fri Jun 11, 2021 4:30 pm
Further advice sought regarding prospective purchase ......
is it a common practice to change the final gear ratio,(ie chain sprockets I believe)?
The original gear ratio was thought to be too high or low?
The originals are available too.
I like to leave things standard as I trust the all round approach of the design engineers...
drix
Re: change gear ratio
Post by drix » Fri Jun 11, 2021 6:09 pm
Stock gearing is a little tall so one tooth less at the front or a few more on the rear is usual.. personal choice based on riding preferences.
There’s a search function on the forum, you can find loads of info on all the usual mods and more :wink:
zakisbak
Post by zakisbak » Sat Jun 12, 2021 7:52 am
ok,thanks
