Carburation and Cooling
Posted: Mon Apr 29, 2019 8:19 am
Hi folks,
Hoping you can help me with a couple of issues.
Firstly one which I assume is carburation - bike accelerates normally all the way through to 100mph then STOPS - just for a couple of seconds - almost like it's clearing its throat - then continues accelerating. Any ideas what might cause this? It's not that I routinely ride at those kinds of speeds but I do like to give her a squirt from time to time.
Secondly, there's already been quite a bit of chat about cooling on this forum so i'm sorry if I missed the one that might have put my mind at rest but here goes.
Bike stationary - temperature creeps up to above 100C - fan cuts in as it should - temperature comes back down to 90C ish. All fine.
Bike on the move - riding back from Birmingham yesterday - ambient temp was around 10C. Temperature needle never left the stop.
Now in anybody's language this is a clear symptom of a thermostat jammed open, but everything I've read on this forum suggests this is quite normal. This only makes sense to me if the temperature sensor is located close to the exit from the radiator, but I think I read one post that said the sensor was located near the thermostat itself which I assume is at the radiator inlet. If that is true I find it hard to believe that coolant was coming off the engine at a constant 50C throughout a 120 mile high speed run. Help!!!!
