Front wheel axle
Wally
Front wheel axle
Post by Wally » Sun Apr 30, 2017 10:47 am
Front wheel is binding when you do axle up?
When loose the wheel free spins but when you put tension on the axle it starts to stop spining.
I've removed the wheel all seems in place it has new bearing,, any thoughts.
Re: Front wheel axle
Post by cobbadiggabuddyblooo » Sun Apr 30, 2017 12:04 pm
If it's not brake bind,
It's a bearing issue. Are they cheap pyramid bearings or good quality Japanese bearings???
Also look as Maybe 1 of the bearings has not been pressed in far enough.
( good example is look at the side with the top hat spacer). If the bearing is not pressed in far enough, the distance is greater from outer bearing face to the crush tube in the centre of the hub, than the top hat spacer length so it presses the centre of the bearing inwards till it meets the crush tube , hence the friction bind. It may only be 1 mm..
The Dymags I run have a weird bearing/spacer and shim set up in the rear with the hub and sprocket carrier and if the bearing is not sitting correctly, the same binding issue arises.
So I have 3 different top hats and 2 shims of different values to fit on the matching sprocket carrier when I'm changing rear gearing.
There is only 0.5mm difference in thickness for the hub shims and 0.5mm difference on the 3 top hat lengths but that's all it takes to create the bind issue.
Wally
Post by Wally » Sun Apr 30, 2017 8:25 pm
Thanks wheels have been blasted & painted as well so maybe that's it
Wally
Post by Wally » Mon May 01, 2017 9:20 am
Bearing are good it seems to be part 6 retainer clutch. (Front wheel parts list)I removed it then wheel would spin when shaft installed
Rod.s
Post by Rod.s » Mon May 01, 2017 2:24 pm
I always go back to the beginning, was it working before? yes, then it is whatever I changed. "part 6 retainer clutch" is unlikely to be the issue, as it was not an issue before :D or was it?
Wally
Post by Wally » Tue May 02, 2017 10:45 am
Bit of a worry too
https://youtu.be/AdFPz7VKffw
Post by cobbadiggabuddyblooo » Tue May 02, 2017 10:49 am
The bearing under the speedo drive may need to be pressed in a little further then once you place part 6 back in, it should spin freely.
Wally
Post by Wally » Tue May 02, 2017 12:19 pm
Did you check out the utube vid
Post by dicky » Tue May 02, 2017 12:55 pm
Wally wrote:Bit of a worry too
You're turning the TRX into a clown bike?
Seems like way to much run out to be just paint.
Strip it all back, check everything twice, then put it back together again.
Post by cobbadiggabuddyblooo » Tue May 02, 2017 4:16 pm
They look like new discs too????
So that's a seperate issue than your wheel bearing binding, correct????
Wally
Post by Wally » Tue May 02, 2017 8:18 pm
Yes
Post by cobbadiggabuddyblooo » Wed May 03, 2017 4:51 am
now that's no good for a new discs mate
Wally
Post by Wally » Wed May 03, 2017 8:19 am
I presume this would give the vibration through the front end when braking?? https://m.youtube.com/watch?v=_8gMwded5G8 Bit hard to see I've centred the disc now
