http://www.ebay.co.uk/itm/Yamaha-TRX-85 ... SwdIFX1Y8K
You'd have to be brave to take this project on
Tealman
No mention in the advert of the 'frame modification'
- davamb
Re: You'd have to be brave to take this project on
"Front fairing has a crack, silencers and tank have damage consistent with the previous owners failure to go round corners upright at speed."
Succinct.
Succinct.
grumpy1
If twas nearer me Id have it for spares.
- highlander
I think I'd struggle to see value of spares - Everything is rusted and needs repaint.
I doubt the carb or even loom is worth recovering. Forks need re-chroming, wheels are already cheap elsewhere, etc.
Might see some value out of clocks and rear shock after an overhaul.
Mind you, the cheeky prices we're seeing for 2nd hand parts in some places ... you never know
