Very happy with changes made over the last couple of days and no fluid leaks to date...
time for an early morning run up the mountains tomorrow to put it through its paces.
Revised the ignition map once again with more advance from 60% throttle sorted the huge fueling / torque dip from 4000 to 6000rpm on my dyno run the other day.
A little homework on the structure of the Std 100 point TRX map opened my eyes to a simple mistake.
I'm sure those with Std motor / pipes / FCR's would benifit from a little more advance on 60-80% throttle from 4,000 to 6000rpm.
Right where you twist the throttle to 100% and coming into peak torque. But the std trx curve on 100 point mapping with its advance peak is only at 100% because of the CV carbies. The TPS is reading 100% but they still rely on vacuum so they are not instantainent like FCR's. TPS reads 100% but the slide is still rising via vacuum.
That's why you need to advance 60 and 80% for FCR's in incriments up to 100% in that midrange peak area.
O2 sensor put back on today and was pretty close with the 162.5 mains at WOT from 4500rpm to 9000rpm it's sitting pretty at 12.5 slowly rising to 13.0 at 8500 onwards.
I just had to move the clip from the centre position with it reading high 10's -11's on partial openings. I settled on 3rd from the top (12-13 AFR) as 2nd from the top found it hunting for fuel.
Look forward to the dyno day read out as I'm keen to try an A-B test with the 2 cans I have.
What put me onto this was the map I put in the ignition had a different TPS calibration so partial throttle gave me a more advanced timing than what was programmed.
Just before going for the dyno run, I re calibrated it to the correct voltage readings and riding to the dyno, I noticed I'd lost a lot of response.
