Fuel leaking from head/exhaust!
666mph
Re: Fuel leaking from head/exhaust!
Cheers Stormy. I'm glad i'm not the only one who's had this problem. I was going to have a look at the pump this weekend. Fingers crossed I may get the bike running soon. The sooner it's running the sooner it's going to get a wash!
- stormy
- Former Member
666mph wrote:Cheers Stormy. I'm glad i'm not the only one who's had this problem. I was going to have a look at the pump this weekend. Fingers crossed I may get the bike running soon. The sooner it's running the sooner it's going to get a wash!
If it (the diaphragm) is holed, spares are NOT available, it's a new pump job.
Glad to have been of some help,
Mike
1996 TRX850 ... gone away for a holiday
1997 TDM850 ... fully restored
1998 Ducati 748 ... it is very red
2000 Thunderace ... simply the best!
2008 Bandit 1250SA .... tis a bit dented now.... damn
I`m wondering if thin sheet viton will do the job,you can buy it from gasket suppliers or indeed try getting some diaphragm synthetic rubber laminate it IS available.
I`ve found this link for interest:
http://www.directindustry.com/prod/zeni ... 41495.html
Most materials are available,it`s just a matter of tracking them down.
I HATE paying for a spare part that can be repaired just as effectively.
DOBBO
Just a couple of queries, wouldnt fuel come out the overflow pipe if floats are stuck? If fuel pump diaphram was holed wouldnt it fill RH cylinder only? May be both tap and pump diaphrams holed remove vacuum hoes from both cylinders and check for fuel. I know both gone together is a longshot but you have got a unusual problem. P.S your engine oil could be contaminated with raw fuel.
always expect the unexpected
I wouldn`t run the bike AT ALL with the fuel loss it`s been showing.
I would find the problem,sort it,drain the `thinned` oil,fill with cheap supermarket stuff,start and warm the motor through,then drain that out,change oil filter and fill with a good quality semi-synthetic.
Petrol washed bores will soon cause accelerated wear,possibly heat seizure and I really don`t believe you want to do that,eh,eh,eh?
(Sorry,came over all Harry Enfieldish there)
666mph
Great news! It's the pump! Here's the pics -
I've see a coulple go on ebay for about 20 quid but i didn't buy till i was sure i needed one. Wished i'd brought one now as i'd be riding my trx to work tomorrow.
Still, not long to go now. Fuel pump and a wash and it'll be tip top (ish)
The seal that's perrished would be very easy to make a copy of if you can get some of the same rubber sheet. I'll look into the link earlier and what's what.
As I found and posted in the link,it IS available but you`ll need to do the research and track some down.
Mate,
I'm pretty sure I've got a spare on of those whole units. If you want me to check, let me know. Yours for whatever you think is right, plus postage.
Dave.
Dave.
666mph
Cheers trixynut, you have PM.
Mate,
Is this what you're after:
..not had it open as three screws are ok but one is a bit stuck. Put some 3-1 oil on it so could probably get it out tomorrow with a bit of time.
Let me know if it's ok as is on the 'refund' basis, or if you want me to open it up?
Dave.
Dave.
666mph
Hi Dave. Don't worry about opening it up. One of the screws on mine sheard off very easily. Send it over and I'll have a look here. I've got 3 good spare screws if it needs it. I'll PM you my details.
Thanks.
Thanks.
- stormy
- Former Member
666mph wrote:Great news! It's the pump! Here's the pics -
told ya!!
666mph
Stormy you smart arse! You could have told me that in March! The bike's been going great since, i've even washed it. If anyone ever needs to make their own gasket/membrane/seal thing the viton sheet is about £16 for way more than you'll need.
- stormy
- Former Member
666mph wrote:Stormy you smart arse! You could have told me that in March! .
Didn't see your post until May ............ I could have waited until next month .....!!!
Thats good to know, at least it means the pumps are no longer a throw away item.666mph wrote:The bike's been going great since, i've even washed it. If anyone ever needs to make their own gasket/membrane/seal thing the viton sheet is about £16 for way more than you'll need.
Mike
- steve speed
were did you get the vitron sheet from ??
