What did you do to your TRX today?
- Racer-unk
Re: What did you do to your TRX today?
I am in the same boat....looking at the goodies current on offer and having to pass for now.....
Are you just going to bore out the trx triple trees to take the 43mm forks???jpe70 wrote:Last two months have been difficult money-wise, but finally looks sorted on the horizont so got around to buy some presents for the Bumble-bee. A set of R6 RSU forks on it's way as is a R6 rear axle complete with all collars and spacers. Yay!
Been fine that way before by Mark on his trx.
jjmoto
I have an r6 top yoke going cheapcobbadiggabuddyblooo wrote:Are you just going to bore out the trx triple trees to take the 43mm forks???jpe70 wrote:Last two months have been difficult money-wise, but finally looks sorted on the horizont so got around to buy some presents for the Bumble-bee. A set of R6 RSU forks on it's way as is a R6 rear axle complete with all collars and spacers. Yay!
- jpe70
Yep, that was the plan after much checking around. Wanted to keep the stock-ish sleeper look. A friend can probably arrange the bore, and then it's no work really. Might do differently in future but for now I couldn't be arsed to swapping stems and finding a proper geometry on different triple's.cobbadiggabuddyblooo wrote:Are you just going to bore out the trx triple trees to take the 43mm forks???jpe70 wrote:Last two months have been difficult money-wise, but finally looks sorted on the horizont so got around to buy some presents for the Bumble-bee. A set of R6 RSU forks on it's way as is a R6 rear axle complete with all collars and spacers. Yay!
- jpe70
Amazing. How long some things can take. Like getting a rear wheel in place. But there it is, in place today.
- Tarwetijger
Topped up the oil.
Besides the normal oil, also my home-made chain lubrication device.
The next door neighbours sister...
- Tarwetijger
You wish!cobbadiggabuddyblooo wrote:The next door neighbours sister...![]()
- jpe70
Removed fork legs, and found out they are heavier than a pair from an R6. What is this bike made of, lead filled steel tubes?
Next up, triples goes away for 43 mm bore.
R6 forks have thinner walled tubes as a weight saving device but at the detriment of strength.
Much like the later model R6 wheels, fart too hard upon them and they bend.
- jpe70
Since I come from racing with the lightest generation old R1, I'm not overly worried. That bike disintegrated when others just washed the dirt off and went on.
- jpe70
Booked her three track days at Brno in june. Yay!
Vinner du på lotto innan så vet du vart det finns mer "ooompfhhh"jpe70 wrote:Booked her three track days at Brno in june. Yay!
Själv blir det 2 veckor på mallis...
- davamb
- jpe70
Ja, lite mer sånt skulle definitivt behövas på den banan. Tur Laila valde en annan grupp med R1:an...Killerwhale wrote:Vinner du på lotto innan så vet du vart det finns mer "ooompfhhh"jpe70 wrote:Booked her three track days at Brno in june. Yay!
