Pictured TRX above
danno
Pictured TRX above
Hi, does anyone know what exhaust system is on the bike pictured at the top of the TRX website?
- Kevtrx849
- Moderator
Re: Pictured TRX above
G,day Danno, it's an Over full system with shortened titanium cans. Sounds awesome, but a bit too loud for some
( HENRY FORD )
( HENRY FORD )
danno
G'day Kev, is it yours? I'm just googling to see if I can get a full over system here....too loud...perfect!
danno
Plus it looks the effin bees knees!!!
- Kevtrx849
- Moderator
Yup, it's mine.If you can find one you will love it. It's a big bore system and it showed 5hp on the dyno with no other mods apart from a K&N air filter. I had the Akra system for a while as well but now i prefer the 2 into 2 look.
( HENRY FORD )
( HENRY FORD )
- Silver
Danno, Finding an akra with the link bits might prove difficult. If you are in uk check out projection components run by kayla on here, thay do a nice big bore 2-1 system.
Has anyone done the comparison between the akrapovic 2-1 and Kaylas set? Silver.Silver wrote:Danno, Finding an akra with the link bits might prove difficult. If you are in uk check out projection components run by kayla on here, thay do a nice big bore 2-1 system.
Can't seem to see one on our search
Looking that I'm about to come by one real soon. (Kaylas (over)system).
- Kevtrx849
- Moderator
The Akra gave more midrange and the motor felt "tighter" The over system gives more top end .Hard to do a real comparison because alot of other changes went on in that period. FCRs and the Over ignitor being just 2 that i can think of. In the end it came down to asthetics though. A 2 into 2 just looks better imho.
( HENRY FORD )
( HENRY FORD )
- Silver
Alex, i havent got either. Mine is a home made big bore by someone else.2-2. would be interesting to have a comparison though. I did consider buying an akra tapered set but it only came withhthe headers and would have needed a y piece fabricating, so didnt persue it.
Dave
Dave
Trixed
I have yoshimura twin trc and they sound bloody good. Makes a duke sound like a squeak..
Always prefer Japanese accessories for some reason.
andyaber
Hi Danno
Where are you?
I have a pair of tiny very loud cans you could buy to give you the same look.
I bought them brand new from SP Engineering a couple of years ago but only used them for a summer before I got a 2-1 system.
They have std 50mm inlets so will fit std headers or Kayla's 2-2. They are only 300mm long and 90mm dia with a massive 60mm outlet ( i have baffle inserts). You will need link pipes to use with std headers which i don't have.
I'm crap at links and such but have a look at the thread titled 'the mongrel' and you'll see pics.
Pm me if you are interesred.
Cheers, Andy.
Where are you?
Cheers, Andy.
