0-60 times
0-60 times
Post by handsomejackuk » Sat Sep 13, 2008 7:38 pm
Hi,
Anyone care to give me some 0-60 times.
Currently my best 0-60 is 4.9 seconds does thiss seem o.k. cant seem to better this
any advice on getting my times down..
lars
Re: 0-60 times
Post by lars » Sat Sep 13, 2008 8:15 pm
How do you measure that?
Re: 0-60 times
Post by handsomejackuk » Sat Sep 13, 2008 9:20 pm
sat nav 0-60 applcation
lars
Re: 0-60 times
Post by lars » Sat Sep 13, 2008 11:04 pm
does that work on tomtom with a PDA?
Re: 0-60 times
Post by handsomejackuk » Sun Sep 14, 2008 10:42 am
Lars,
should do providing you got gps adaptor on your pda check this link out
http://classic.pocketgear.com/software_ ... p?id=24172
jak
Kayla
Re: 0-60 times
Post by Kayla » Sun Sep 14, 2008 3:50 pm
I have no idea what it is, but it should be quicker than 4-point-odd seconds. The bike should hit 60+ in first on standard gearing easily- just pin it in first :D
Re: 0-60 times
Post by handsomejackuk » Sun Sep 14, 2008 10:01 pm
to honest, I think the slow time is due to the delay in pressing the button on my sat nav, and releasing t clutch and pinning it if it was automatic program it would be lot faster
sherlock
Re: 0-60 times
Post by sherlock » Mon Sep 15, 2008 8:46 am
When they were released, I believe the 0-100kmh (0-62mph) was 3.8 sec
elementary my dear.....
bobtrx
Re: 0-60 times
Post by bobtrx » Mon Sep 15, 2008 9:33 am
Can,t say that I ride :lol: that slow , I do know my old bike will do 180 in 3rd [-X
catch ewe later bob
Triton
Re: 0-60 times
Post by Triton » Mon Sep 15, 2008 12:09 pm
Okay, stock bike 3.985 0-100km/h.
178km/h terminal speed.
Recorded at Eastern Creek in 1998. VERY slow TS!
TonyDevil
Re: 0-60 times
Post by TonyDevil » Mon Sep 15, 2008 2:30 pm
i find 0-60 on a TRX to be very slow, mainly coz of the stooopidly tall first gear
theres a set of lights on a roundabout near me
on the TDM and XTZ if i gun it i can make it through the next set on amber
the TRX doesnt make it before it turns red
TDM900 2003 - commuting tool
Z750 hardtail - project
Triton
Re: 0-60 times
Post by Triton » Tue Sep 16, 2008 3:23 am
Sorry guys, the terminal speed is for the 1/8 mile.
Re: 0-60 times
Post by phuk72 » Tue Sep 16, 2008 8:16 am
Triton wrote:Sorry guys, the terminal speed is for the 1/8 mile.
are you sure? That's the sort of speed I would expect a standard TRX to hit over standing quarter (in 11ish seconds)
Triton
Re: 0-60 times
Post by Triton » Wed Sep 17, 2008 3:55 am
D'Oh... 1/4 mile. OOOSDC memory kicking in. ET was 11.761... slow! :oops: Did a 11.307 on a stock ZX-6 the same session. Raced a rotary engine "Pacman" Madza RX-3 and whipped it! They were claiming 9's! :D
Re: 0-60 times
Post by Quan-Time » Fri Sep 26, 2008 2:15 am
if you went a bit fussy, such as getting a few tie-down straps. Strap your forks down as much as possible. Put the front brakes on, bounce on them, and have someone keep pulling on the tie down to make them stay there. You can do it via the triple clamps if your tricky.
Let your rear tyre down a fair bit.. in the region of 20psi. Yes its flat. But the contact patch will be HUGE.
Also set your compression, rebound and preload to stiff as a fatman (bobtrx setting. heh.. couldnt resist).
Both feet on the ground, out wide if you can, but the inside of your foot on the ground. You get good stability without much drag.
Once you pull your feet up, dont EVER put them down again.
For launch, pull yourself as high up on the tank as possible, to the point where it feels like your doing a chin up. Your arms should be fairly flexed. But still comfortable. Soon as those feet come up (within the ~10 - 15ft mark where the clutch should be all the way out). Move your ass back as far as possible when you bring your feet up. you should now be right back in the seat. Depending on the power output, you may need to stay forward to prevent too much unicycle work.
Hang on and keep bangin those gears.
A TRX should be good for 11.5, not much more in stock form. something with 90hp rwhp+ should be looking at 11 flat if they have a few extra teeth on the rear. The trap speed will be inherently faster, but the ET will be very similar. I cant see it being much faster than this. If at all. Its not a real sports bike, its just not geared / designed for it.
Hope this helps.
