gearbox linkage
Boulevard82
gearbox linkage
I've been having trouble lately changing gears on my trx. The problem has been the bike going into neutral when changing up, as well as the bike jumping out of gear occasionally as well. I'm guessing the problem is with the gearbox linkage. I'm wondering if anyone has any advice on how to fix the problem, as I couldnt find anything in the manual on this topic.
- Con Rod
Re: gearbox linkage
there is a dot on the output shaft that should line us with a corresponding dot on the linkage. Then adjust the lever height to suit using the threaded bar.
Re: gearbox linkage
Would do no harm to remove the pivot at the gearchange, clean up and lube with coppaslip - especially if used in Winter.
Also check the clutch adjustment - do the gears change ok with the engine stopped? If so, could be clutch related
- Gordo
Re: gearbox linkage
Not so much experience with sportbikes, but, when dirt bikes do that, it's generally a worn/bent selector fork problem..Boulevard82 wrote: The problem has been the bike going into neutral when changing up, as well as the bike jumping out of gear occasionally as well. I'm guessing the problem is with the gearbox linkage. I'm wondering if anyone has any advice on how to fix the problem,.
Gordo-
Re: gearbox linkage
You've got the right direction Gordo,..hesitant to suggest..but I'd be inclined your way.Gordo wrote:Not so much experience with sportbikes, but, when dirt bikes do that, it's generally a worn/bent selector fork problem..Boulevard82 wrote: The problem has been the bike going into neutral when changing up, as well as the bike jumping out of gear occasionally as well. I'm guessing the problem is with the gearbox linkage. I'm wondering if anyone has any advice on how to fix the problem,.
Gordo-
I cringe when I see a motor bike rider crunch down the gear lever at lights ..
The only OUT might be lever adjustment or maybe steel capped boots are in play..
