Oil filter o-rings
skull-candy18
Oil filter o-rings
Post by skull-candy18 » Mon Jan 20, 2014 5:16 pm
I'm just about to service my bike and I'm missing the small filter cover o-ring. I also can't find it anywhere with the part number on here (except USA)
Can I change the filter without replacing the small o-ring ?
M.V.
Re: Oil filter o-rings
Post by M.V. » Tue Jan 21, 2014 12:47 am
The one on the filter itself? I imagine you should be able to re-use the old one, make sure you replace it next time though, they're under a bit of pressure IIRC.
skull-candy18
Post by skull-candy18 » Tue Jan 21, 2014 8:25 am
The little ring that goes on the housing. Its the arrow on bottom right of this picture and goes on the metal spacer. I ordered all my stuff from wemoto and I presumed the small o-ring would have come with the large o-ring. It seems to be quite hard to buy on its own and my nearest Yamaha dealer is quiet far away. I though I could just re-use it but my Haynes manual says to replace.
M.V.
Post by M.V. » Tue Jan 21, 2014 9:17 am
Does the Haynes say to replace it every filter change? I've never replaced one yet... :shock:
Post by cobbadiggabuddyblooo » Tue Jan 21, 2014 10:39 am
Same here, I've done around 20 oil changes and I've never replaced it.
Post by Tarwetijger » Tue Jan 21, 2014 11:28 am
M.V. wrote:Does the Haynes say to replace it every filter change? I've never replaced one yet... :shock:
Yeah, but they say that with every single O-ring. :|
I replace them sometimes, not always.
KEDO item 91629 is handy.
http://www.kedo.com/ssl/php/art_detail. ... c3a0ba74b2
skull-candy18
Post by skull-candy18 » Tue Jan 21, 2014 12:22 pm
Thanks, hopefully it will be fine this time. I've seen the kits but I've already purchased the filter and large seal/crush washers so didn't wan't to have to buy it all again.
I'll be doing it shortly so hopefully no problems arise :)
Stu99
Post by Stu99 » Tue Jan 21, 2014 12:32 pm
Yes it does. But then again if you followed Haynes pre ride inspection every ride you'd get to work after lunch every day.
:lol: :P :lol:
skull-candy18
Post by skull-candy18 » Tue Jan 21, 2014 7:41 pm
:lol: :P :lol:
This is very true.
Well I serviced it and all went to plan apart from not having a small crush washer and losing the keys to my shed for my locktite.
Post by fung » Tue Jan 21, 2014 11:51 pm
For the sake of a few dollars/pounds/euros i always prefer to replace all washers and o rings.
Both the left side drain plug and the right side long filter bolt have crush washers.
The large and small o rings are cheap enough and they get a squash, get oily/greasy and get hot, so why not replace them at each change :-)
Post by Con Rod » Wed Jan 22, 2014 12:41 am
fung wrote:....so why not replace them at each change :-)
yep pure laziness on my part. The large o-ring I don't have handy and never think to get it, same with the crush washers. I have a stack of the smaller o-rings so no reason for me not to change them other than just laziness.
And surprise surprise I commonly get oil weeping from the filter cover
M.V.
Post by M.V. » Wed Jan 22, 2014 5:03 am
Stu99 wrote:Yes it does. But then again if you followed Haynes pre ride inspection every ride you'd get to work after lunch every day.
:lol: :P :lol:
No wonder they call it "The book of lies"
Still given that the rear wheel came off my pushbike the other day, after I had ridden to & from work, maybe a pre-ride inspection isn't such a bad idea :P
Stu99
Post by Stu99 » Wed Jan 22, 2014 10:14 am
:lol: :P :lol:
"The book of lies" :sign5:
But you know I always change all o-rings and washers with every change. OCD old me.
No doubt it's possible to get away without changing them every time but as fung pointed out, for a few bucks peace of mind is cheap.
