Guys,
The rubber (anti-bottoming) damper in my rear shock is buggered.
I've checked the parts list and it appears that it's not sold as a separate part by Yamaha.
Does anyone have any suggestions as to what I can do?
Can I turn one up out of some material in my lathe?
If so, what do you suggest?
Any other alternatives?
Rear shock rubber damper split
- WR450FGreg
Re: Rear shock rubber damper split
Contact Hagon, they`ll likely sell you one that will fit:
http://www.hagon-shocks.co.uk/
If you`re comfortable fitting it yourself that`s the easy option.
