compresion damping
cheesie
compresion damping
Post by cheesie » Mon Dec 18, 2006 6:41 pm
should the screws to adjust the damping on the fork tops keep turning, :? thought they should of stopped when they reached hardest setting never had a bike with damping adjusters before
Post by HansJ » Mon Dec 18, 2006 7:11 pm
They should, they have half a "free" turn between max and min, and 4 (?) selectable "clicks"
Post by trixynut » Tue Dec 19, 2006 11:38 am
Yep, as Hans says, they go "click, click, click, click, pause...click etc (back to the start)" !!
cheesie
Post by cheesie » Tue Dec 19, 2006 6:52 pm
thanks lads
Post by dandywarhol » Wed Dec 20, 2006 2:32 pm
Ermm..............it's the rebound damping thats adjustable - the compression damping is adjusted by oil weight on standard TRX forks
SuperMono
Post by SuperMono » Wed Dec 27, 2006 12:32 am
They will keep turning if the factory adjusters have been removed and aftermarket shim stacks (cartridge emulators) have been installed.
What do you mean I can't ride 7 bikes at once?
cheesie
Post by cheesie » Wed Dec 27, 2006 9:50 am
thing is I can see by the top nuts someone has had the fork internals out, and the forks feel stiffer to the bike I had a test ride on in the summer so was just wondering with adjusters turning full circle have the gold emulaters been fitted, maybe I will have to just take them out myself and see
Post by HansJ » Wed Dec 27, 2006 11:34 am
Correct, itzs only the rebound that is adjustable. If emulators have been fitted, You should have no clicks at all, since the adjusting rods have to be cut (and the adjustment valves are actually replaced by the emulators), so if You have clicks, but stiffer suspension, my guess is that previous owner changed oil and/or springs.
cheesie
Post by cheesie » Wed Dec 27, 2006 4:49 pm
yes rebound it is, comp damping was a whoopsy yes it is clicking
